Andros constantinou Posted August 8, 2020 Report Posted August 8, 2020 Why does my vin number window on the front screen fill up with water when it raining on my 2010 xf Quote
JOE-DOT-COM Posted August 9, 2020 Report Posted August 9, 2020 hi most favorite problem would be leaking windscreen if its had a new screen in the past, most probably not fitted correct I would assume you would need to get the windscreen removed and refitted to cure the leak cheers Joe Quote
Andros constantinou Posted August 9, 2020 Author Report Posted August 9, 2020 Hi its been replaced again because of this and the same is happening again. The fitter said its leaking through the pollen filter housing which is sceptical as it wasn't leaking before the original screen was changed. Quote
Andros constantinou Posted August 9, 2020 Author Report Posted August 9, 2020 On 8/9/2020 at 2:58 PM, Andros constantinou said: Hi its been replaced again because of this and the same is happening again. The fitter said its leaking through the pollen filter housing which is sceptical as it wasn't leaking before the original screen was changed. Expand Quote
