Hi all. Did anyone successfully sorted out the leaking windscreen panel? I've tried various things and still having a leak..I've even followed the repair guide and bought patches, but that didn't work at all..
I used a silicone RTV gasket formula to seal between the actual windscreen and the rubberised seal of the scuttle. The seal bulges and lets water into the engine bay. Since then all good except when I need to remove it I'll have to reseal it again.
Did you use any special rtv? Did you put it directly on the edge of the windscreen or on the panel? Anywhere else apart from there? Thank you for your reply! Much appreciated
Just a tube of RTV from my local auto parts store. See the dusty strip behind the wiper arm? That's where the paste went - not the way I really want to do it but worked well enough.
