New member
Chris Neil
I have put a deposit on an XK 150 convertible 55 plate with 62k on and a full JSH  to scratch an itch I have had for a few years. It has a great service history having been owned for 7 years by an JEC owner and I have looked at the car in some detail and test driven.
Can I ask  a couple of questions
Maintenance
Are maintenance costs as high as some suggest ? ( I appreciate they will be higher than average but have seen some horror stories)
Over winter storage
I am picking it up in a week or so when I will probably have a few local runs then store over winter until spring. Are there any specific recommendation or suggestions that people do when they put them away for winter?
Water in boot
I did find water in the boot and it was suggested this was because it had just been jet washed which did not convince me 100%
Is there a common issue with water ingress into the boot and if so should I be concerned or is there a known issue and fix ?
I feel I have done as much as possible to check the car over and as I said,  the service history is impeccable but are there any specific things I should look for before I pay final amount and collect the vehicle?
Thanking you in anticipation
Chris
Hi Chris,
As you’re in God’s county, Chris Isles at Doncaster is the guy you want for servicing. Very friendly, knowledgeable and reasonable prices.
I drive mine throughout winter unless there is snow on the roads however, 3 things if you want to take it off the road, pump the tyres to around 45psi, will help stop flat spots. Fill the tank with fresh fuel and get yourself a CTEK charger/maintainer.
As for water in the boot, I personally have not heard of anyone with this problem on an XK so worth check the seals around the boot and lights.
Hope this helps.
Hi Can anyone tell me , is the width of a 55 plate XK convertible quoted in specs when the door mirrors are extended or without?
If anyone knows the full width with mirrors out could you please let me know, ( just buying an XK and checking if it will fit in my garage
Chris
Apologies for posting her but could not figure out how to generate new post
Thanks Jim
It is an XK not an XK 8 and I am led to believe it was built in December 2005 and registered early 200ing number 85 off the production line....
Its going to be a bit of a squeeze but it will fit..... just
Hi Chris,
You have had some excellent information from Jim.
I was thinking a bit about the garage and the problems I have had.  My garage is not perfectly angled, as I have found out after 30 years. It is also 20 feet long but was not wide enough for my Rover Sterling , so I gave up, and wife's Toyota Yaris lives there now!  I didn't even bother with my s type.
      • 6 replies
