Hi guys
I have an inquiry, if you open the armrest in between the seats there is the power socket and aux socket and because my Jaguar is a base model that’s all there is, but in models above mine there is a USB charging point too. My question is if I buy a replacement type with one that has a USB plug on it, is it just a plug and play scenario ? Is there a power wire there for it or does the whole top get powered from one point and it’s just a matter of swapping the tops
thanks in advance guys
  • 10 months later...
Es ist aufwendiger. Du brauchst ein Portable Audio Modul 8X23-14D212-AA mit passenden Kabeln, den Einsatz in der Mittelkonsole mit USB, AUX und IPod-anschluss. Und du musst es Im CCF programmieren.
