Constant airbag light
Mark Five
My airbag warning light is on constantly and it doesn't flash when switching on the ignition. My local Jag indie can't read the airbag module (therefore no codes) and has advised it's probably a complete module failure. He's also advised that airbag modules are 'locked' to the car, and replacing it would prove very expensive (around £1500) as such modules aren't cheap and would need re=programming by a dealer.
So right now it looks like I've got a really nice, 4-wheel paperweight - unless anyone has experienced this and successfully sorted it? All advice gratefully received!
Cheers, Mark
Good Morning,
I don't know  if this will help or not!  I had this on my S type a few months ago.   By keeping the battery fully charged it has eredicated it.
I like your white S type I would have prefered it to my silver!
grumpy 1941
stay safe😀
Thanks for the replies! I'd already made sure the battery was kept fully charged, but checked it again anyway. I guess I'll just have to bite the bullet and pay the £99+VAT my local dealer wants to plug in their reader!
Cheers, Mark
air bag modules are plug and play as long as you get the same part number, require no programing, you just have to make sure it has the same amount of airbags
most descent code readers will read air bag modules
I have a cheap icarsoft and that reads the airbags on most cars including jaguar
plugging into Jaguar ids/sdd software will tell you exactly where the fault it
also air bag modules are cheap second hand, try auto reserve jaguar, they sell second hand part and there guaranteed to work
Thanks for the clarification Joe - I also have the iCarSoft reader but it doesn't see a fault, nor does my indy's comprehensive equipment. It seems to be completely invisible, so I'm inclined to think it's fried.
Luckily it's not my daily drive and, having looked through the workshop manual, it seems to be a fairly straightforward job for my skills set. I'll get the old one out and make sure I replace it like for like.
Cheers, Mark
try unplugging the airbag module a few times, just incase of a bad connection
if the battery has been flat in the past, its a common time for them to fail
air bag modules can be bought for less than £20, worth swapping and see what happens
      • 6 replies
