Have you checked the fuse for the blown headlights? Quite often the surge takes out the fuse. Chidders
Just asking dose the headlight flash work on the stick ---dose low beam work ??? and are you sure you have the correct Bulb ???
Think you need to get any DTC codes read. Like everything else on these cars it is not a simple wire to the Bulb, an earth connection and a switch. There are a whole host of computer modules, leveling sensors, motors, LAN connections, warning lights etc. etc. A fault in any will cause issues. I am waiting for a diagnostic on the "Camera Unavailable" issue after my supplying non-jag dealer diagnosed faulty parking sensor which is still not working after replacing it 😞 In my case itis probably a faulty front bumper wiring loom which if faulty closes down both camera and parking assistance system and gives a really loud 3 second warning so that you know you are "flying solo". Without a DTC (Diagnostic Trouble Code) you end up chasing your tail and just replacing parts and hoping it works.
