Hi have 2005 S Type 2.7 auto central locking works but only drivers door doesnt lock ,locks with key ok .
Obvious first question is: Have you tried changing the fob battery?
If yes then it might be a fault with the door module, behind the trim in on the drivers side door.
Also check Fuse F22 hasn't blown. Should be in the fuse box in the drivers footwell.
