This might be one for the Technical Guys, I have a weird burbling sound coming from the engine, Its not affecting the performance or smooth running of the engine, I have taken it to a Mechanic but he cannot give me an answer to this , If any other X type V6 Sports Owner has had a similar problem with this burbling noise issue I would be interested to know what is causing it.
Many Thanks to all for a Great Forum
BAZZER RN
It sounds like the cooling system is probably cavitation which is caused by either a hotspot in the coolant system or a faulty pressure relief cap which is cheaper to replace to eliminate this as a possible cause.
Thanks Trevor
It is a bit of a mystery . seems to be coming from the from part of the engine but very difficult to pin the noise down from where its coming from, its got a few Mechanice scratching their heads at the moment, I had hoped that maybe another X type Owner somewhere had a similar problem , but thank you again for your suggestion I will have another look at this over the weekend and should I find anything I will let the Forum know and it might just help someone else who has this problem.
Cheers Trevor
BAZZER RN
