I've just bought a 2009 se estate and the parking sensors don't work the the on off button is flashing so there's power to them any info would be appreciated
Hi David, the button flashing is because there is a fault within the system. A code reader will help point you in the right direction as to what has gone wrong.
You could check the module is clean and dry and also the connectors.
