Hi everyone, I'm new to jaguar ownership and after some advise, I recently purchased a 2006 XKR 150 4.2l convertible, it was a private sale and had a full tank of fuel when I picked it up, on filling it for the first time it took me about 10 minutes to put about 20 litres of fuel into it, I googled the problem and found some advise saying turn the nozzle 90 degrees clockwise, I tried that and it was better but still a little slow, got 45 litres into it and that was it, thought it must be full, turned ignition on and only showed 3/4 full, I had the breather tube checked, that was clear! Any ideas about possible causes?
Without wishing to duplicate a post, could I just add a few “update” comments, having the same problem and looking at every forum I can think of! Firstly, this is a common Jag problem and not restricted to XKs; indeed, I understand Jaguar issued a modified fuel filler neck for the XF. It may be related to oversensitive pump sensors, of course, but actually in some cases, its the car not the pump! Also, note, the filler system is different (on XKs,) between EU and NA models, so likely that the EVAP canister problem suggested on many forums does not cause the issue on UK cars. The other point to be aware of is that most JLR dealerships will “claim” ignorance of it being a car problem, (mine certainly did!)
if you are unlucky to have a vehicle that suffers, then please try all the self help suggestions ie angling the nozzle, turning it to 90 degrees etc. It may work! However, there are clearly some problem cars which no matter what you try, the slow fill problem may persist. Very sadly, I have not yet stumbled upon the solution, and as mentioned, not getting any help or advice from JLR either. The problem certainly seems more prevalent as the tank fills to ward’s capacity, and to make matters even more frustrating, sometimes filling up works okay. It is not related to different pumps either, because I can only access one pump locally with E5, (and before anyone suggests it, happens just as often with E10)
If anyone else has discovered a fix, would be delighted to hear 👂
I have tried all the things such as turning the nozzle to different angles, even got my local garage the check the breather tube, then thought it was just my local garage pumps been to sensitive,  no, as everywhere else was the same, then one day I literally just pushed the fuel pump as far as it would go into the car, I know this sounds a bit stupid, as every other car I have owned could be filled with the pump only 2 inches into the filler, it had a full tank in no time at all, since then, I have had no issues at all, all I can say is, if the pump will go further in, then try it, it could save a lot of embarrassing moments at the garage, hope this helps.
Thanks Steve, will certainly try this next time! The infuriating thing is that occasionally it fills ( and I generally use the same garage and pump for E5), without any issue. Go back 10 days later and bad as ever
  • 3 months later...
quick update; did a recent road trip, excess of 600 miles , so inevitably regular fills of tank. first 2 fills, same issue, very slow fill. Third time noticeably quicker, fourth fill up, almost  no issue, filled up carefully as ever but no cut outs on the put[p sensor and filled at "full rate". Subsequent fill at a different garage, no issues. Question; is the problem more likely if we are not driving the car often/ long distance so there is a pressure build up?
3 months on, and frightened to post, but the car seems to have cured itself. The only other useful tip I have learned after the months of frustration, is that now, my routine is to ensure the nozzle is fully into the fuel neck filler, (even to the extent of feeling I am forcing it into the vehicle), and then to increase the pump flow pretty rapidly and "go for it"! When it was constantly cutting out, I was pussyfooting about fearful of filling too fast, it seems now easier just to hit the gas literally.
  • 4 months later...
now almost 6 months on from my last "update" and my car/ fuel filler is behaving itself, touch wood!!!! routine still, insert pump nozzle 'firmly' and ensure fully engaged, and increase fill rate pretty rapidly . Seems to be working and now no longer the idiot blocking a pump! Relief.
I did read one other tip elsewhere; member suggested that its maybe caused by a build up of pressure in the tank if the car is left standing, eg mothballed over the winter? His solution is a. leave the tank completely full when he knows the car is going to stand, and b. before he next uses the car and goes to fill the tank, he wedges the filler cap open for 24 hours. His view is that that "releases" and pressure in the tank?
It does kind of chime with my experience that my filling issue seemed to get better when I was using the car more frequently. When I bought the car, it had been very little used for a while as previous owner had passed on.
Thank you for the information. Just bought a beautiful XK 2011. And she is having the same issue, and she had pretty much set for 2 years.
Hi Folks, in all of these cases the fault does not lie with the car but the petrol pumps which have their choke cut off pressure set too low. The fault should be notified to the attendant in order that he can log it as a fault for rectification during the next pump maintenance cycle.
I appreciate it is frustrating and that their are some "apparent" tricks to circumvent the isue, but believe me, this is a well researched issue and it is always the pump at fault.
N6 JMX
N6 JMX
Sorry, but really cannot agree with you based on my personal experience. So, each of 4 filling stations in my home town has "incorrectly" calibrated pumps? That, despite, successful fill ups on the same pump with our other petrol fuelled vehicles?  Or, the same filling stations (one of two with 98 octane which I use), filling the XKR successfully on occasions, but the next time, the problem recurs ? It appears from numerous posts on various Jag forums that this is a relatively common issue, not confined to the XK range, and no-one has come up with a "universal" fix. My own experience remains, that its much more likely to occur when the car hasn't been frequently used, and tends to sort itself out once wee start driving them again That has certainly been my experience with my last 2 XKRs.
Hi Philip, we are each entitled to believe what we want. My experience has shown that it is not the fault of the car.
N6 JMX
N6 JMX
Oh indeed we are, but your comment was “in all of these cases”, which to me seems rather prescriptive?
And, by the way, doesn’t actually help the OP very much with his question, does it?
This is the workshop image of the fuel tank and fuel filler pipe on the X150 model. If you open the image and zoom in, you will see that the vapour pipe from the fuel tank to the filler head, connects to the filler head in the funnel element of the assembly. If you don't fully insert the fuel pump nozzle into the filler head, then the outcome should be obvious.
The standard petrol pump choke back pressure is normally set VERY low so as to prevent fuel spillage onto the forecourt and across folks paintwork.
N6 JMX
