Hi when I fill up with fuel the trigger on thd pump keeps clicking off, shutting off the fuel flow. It seems like the pipe to the tank has some sort of restriction down it so stopping it flow properly. Not sure if there is some sort of anti theft device part way down the pipe which is not operating properly when I insert the fuel nozzle.
Misfueling device has been triggered. There is a yellow plastic tool on top of the battery to reset it. Basically push it down the filler and lift
Look down the filler and you will see a bright yellow flap with a symbol of a manual on it.
Instructions are in the handbook or just google it as there are good videos on youtube. Land Rover has the same system.
