install on a 2005 Jaguar S Type R
Afternoon All, i have been investigating the possibility of upgrading the factory audio in the s types and x types alike - making it as easy and pain free as possible.
im an official Audiotec Fischer Dealer, i supply’s edge, vibe, match, helix, brax and Hybrid audio. i have found a way to integrate an aftermarket amplifier which has 6 channels and can support 2 subwoofers all from one unit that is COMPLETELY PLUG AND PLAY and retains all original functionality !
no wires need to be cut - i used a jaguar fit harness and a 5 meter long extension loom to run the amps wiring to the boot so that the amplifier will sit in where the oem cd changer/nav unit is. this amp requires no extra power or ground wires to be run just 1 simple cable from the head unit to the boot!
the amp itself is a Match PP62DSP - its a fully customisable 64bit processed amp that is far far superior to amplifiers found in modern cars today.
this amp also supports the expansion of a HD bluetooth card so that you will be able to steam music directly to to the amp with LOSSLESS bluetooth streaming capabilities.
if you are interested in bringing your jaguar to the present day and having one heck of a sound system please get in touch - supply speakers and Subwoofers for the parcel shelf to finally solve an age old problem with upgrading these cars
