the 2012 XKR I have bought has what I assume are black sooty/carbon deposits on the inside of the quad exhaust tail pipes
pretty solid and tried wheel cleaner which doesn’t do much
wondered if any members had more success removing these black deposits
thanks
David
What you need is one of those rotary brass wire brushes that fit into an electric drill. You then need a small rotary polishing mop with metal polish and away you go.
That’s a good idea as have a set of these wire brushes that go on the drill
thanks
neighbour suggested oven cleaner and a Brillo pad if anyone has experience of using this?
If it’s as baked on as you say then even oven cleaner won’t shift it. 10 minutes with the drill, job done.
  • Thanks 1
  • 1 year later...
Done mine as Jim suggests and then used UHT spray paint to re furbish, (stove paint will do the job too), looks as good as new
Cleaning the outside - of course - but I can't say it's ever occurred to me to clean the INSIDE of my exhaust tailpipes!
