Hi I have a 2002 3.0 SE which keeps throwing up fault codes P0171 and P0174 I’ve cleaned the MAF sensor, changed the air filter and looked for vacuum leaks but so far I’ve been unable to sort out the problem, I’ve noticed that once I’ve cleared the codes they only come back when I take the car out for a drive after about 5 minutes, has anyone any ideas what may be causing the problem, many thanks
Paul
These codes relate to Left Bank and Right Bank fuel mixtures. Could well be Lambda Sensors, certainly worth a check on them.
Best of Luck, John
HI
P0171 AND P0174 are usually lean codes, air leaks between engine and maf, so a split pipe or perished hose
check all those little hoses, lots of garages have smoke machines that fills the inlet system and you can then visably see where it leaks from
