i have an x type 2.2d it has the muti changer in boot seems to be ok. but when i press cd in car nothing happens, am i not doing something i should
Brian
Having no CDC button suggests that the CD Changer may have been ad add on, after new. Is the Changer actually live, I.E. wired into something or is it just installed and not live? Does the CD in the dash actually play a disc?
Best Wishes and Good Luck solving the Problem, Regards, John
hi john, no cd slot on dash. the multi one in boot is live and lods and ejects ok. just a cd button under screen on dash. does nothing when i press it.
Brian, Do you have a circular Volume button about the size 2 cms on the controls on the radio. Have you tried pressing this button as on my S Type of the same era this button will turn the CDC on and off as well as control the volume.
Cheers, John
Brian,  Sorry but I have nothing further to offer you. I am of the feeling that the equipment (changer ) in the boot is not original and not connected to anything we know. I am assuming rightly or wrongly that the cat is a recent purchase. If that is the case and the CD player has never worked, would it be worth trying to contact the previous owner/seller and asking for information? Regards, John
yes maybe john, but if no single cd on dash i think the multi one is origional, maybe someone else can throw some light on it, all the best john
Brian,  My S Type has the changer in the boot. It also has two controls under the screen CD and CDC, there is also a slot for a single CD which is the CD button. The changer in the boot is controlled by CDC and an on screen selector for any of the six tracks and any tracks on each disc.
Cheers, John
HI
Post a pic of your dash
not enough info
do you have lcd dash or touch screen, cd and cdc buttons are next to each other
cd player came as standard, cd changer was optional,
thanks for posts lads. sorry dont know how to do pictures. it is a touch screen with sat nav, cassette deck, under cassette deck  is a button for that annd a cd button. no cd slot.
its either cd or cassette
you dont often see cassete decks, thats whay there no cd
you could swap the cassette deck for the single cd in the dash, cheap on eBay, plug and play, make sure it comes with the code
