hi I keep getting this message up on the dash when the car is warm any ideas thanks the message is Oil level critically low
  • Sad 1
Obvious advice is to check Oil level and then top-up accordingly. If Oil level correct next stop would be level sensor but I would certainly be very wary of not sorting it ASAP. If Oil level is dropping it is either leaking externally which should be visible under the car or being burnt in the engine which should be visible as blue tinged smoke. Runing with insufficient oil risks a whole host of hurt 馃槥
  Pasted as rich text.   Paste as plain text instead
  Your link has been automatically embedded.   Display as a link instead
  Your previous content has been restored.   Clear editor
  You cannot paste images directly. Upload or insert images from URL.
