I have finally received my diagnostics reader, the iCarsoft as recommended. I plugged in following my recurring Restricted Performance and found these two faults - 1. Manifold absolute pressure - mass or volume air flow correlation 2. Exhaust gas recirculation cooler - bypass control circuit. Can anyone please explain the faults and how they can be resolved. Any help greatly appreciated.
  • Sad 1
what are the codes?
maps sensors usually either gets dirty or just needs a new sensor fitting, egr code would give more info
Hi Joe, failed to see the codes in top left hand corner of reader so here we go.
P006A-00
P245A-77 Historic
P0102-00 Historic
P0110-17 Historic
Regards Frank
P006A-00 normally relates to a manifold issue, could be cracked or a pipe that has become loose, basically detecting a drop in pressure.
Others are historical.
Well Darren (Tomato) was right there was a crack but not the manifold, the rubber pipe below, picture attached. Found a good mechanic locally diagnosed and found fault in 5 minutes following two clowns that said EGR and the other electrical fault. Diagnostics labour and part  £ 75.50, very reasonable. I think he will be my go to guy now, friendly, knowledgeable and reasonable.
  • Thanks 1
