Coolant Leak, Heater not blowing warm air. I've tried looking on topic. Bit of advice please?
Posted (edited)
Hi all, Hope it's not been brought up too often. My Jaguar 2003 XJ6 3.0 V6.. OK: When i check and fill the coolant, start the car, let it run - it doesn't leak. When i'm in traffic queues (not unusual here in London) the temp gauge starts rising, i get a low coolant msg on the dash (so i'm assuming it's now leaking coolant) as soon as i start moving again the temp gauge drops to the normal midway point. When i got back today from one hours London driving i noticed there was a coolant leak. (facing the car it's coming from the left hand area - left of the radiator) Also and very probably related, the heater doesn't blow warm air.)
I only bought it as few weeks ago and the poor thing had been sitting not being used for some months. I'm taking a guess at a split hose etc. Any more informed mechanically minded chaps out there?
I've had quite a lot of Jaguars, this is my first V6 tho' - i've had XJ8's XK8's XKR etc.
I'm in Central/North London, any Independents you can recommend to sort this out?
Much thanks.
Edited by CamdenJagBoy
miss spell
Update, i've had a look underneath it, the leak is coming from under the radiator on the mid/left, steady like a just slightly turned on tap. So - is that a case of getting a local garage to replace the radiator, or should i try a repair ?? Is this also the source of my heater blower not blowing warm air? (must be i assume? - not getting a vacuum?)
Personally I would be inclined to have a new radiator, first cost usually being the least cost. Especially if the repair lets go at some stage and you lose all of the water.
Regards and Best Wishes, John
