Windscreen Washers
Frankiej
I’m having this problem too.
Ignition on and they work, start the engine and they might work once or twice and then stop.
Turn the engine off and then switch ignition on and they work again.
Very strange.
3 hours ago, Frankiej said:
A simple solution after all. Took it to my new mechanic and immediately he said the pump was faulty. Replaced the pump and all is well 😊
Usually this or a blocked filter in the water pump. Replacing is normally better as still have to do the work to get to the pump and the part is not expensive.
Excellent news and thanks for the update.👍
