1 hour ago, wingman said:
Surprised no one has mentioned that this is illegal
Care to elaborate?
an MOT failure.
Hmmmm, back in February, DVSA updated things and basically said as long as the beam pattern was correct, it was fine.
However, a couple of months later, this was changed again - now so few people know where they stand on this, most of the time as long as the beam pattern is ok then it's all good. I wonder how i would get on with an obviously incorrect beam pattern using halgen filament bulbs but a correct beam pattern using LED bulbs in the same headlamps?
3 hours ago, LairdScooby said:
Care to elaborate?
The only bulbs that are compliant with the law are marked H4, anything else is an MOT failure, it's quite clear I'm afraid.
No way can you fit an H4 into an S Type! 😮
sorry H7 apparently, anyway it has to be a Halogen, it's the law I'm afraid.
Where would i find that in the Constructions and Use Regs? Or Destruction and Abuse Regs if you prefer.........
4 hours ago, LairdScooby said:
That's the MoT regs, what about the C&U?
No idea, does it really matter? without an MOT it can't be on a public road, so C&U is rather a moot point anyway?
My other car has developed an ABS fault at the moment, it's still perfectly legal to drive but won't pass the MoT as it is unless i jerry-rig the ABS light to the SRS light. Alternatively i could just fix the problem but that might be easier said than done given it won't let me read the codes. Sort of suggest the ABS ECU is belly-up but that's for another forum maybe.
Likewise there is (or at least wasn't last time i checked) nothing in the C&U about the light source - the moving traffic offence would be dazzling oncoming motorists if the LED bulbs gave an incorrect beam pattern but having them fitted isn't illegal. They won't pass the MoT because of a govt knee-jerk reaction to the mass influx of cheap Chinese LED headlamp bulbs that simply have a large COB LED that gives no definite point of light source, just a huge blob of light that gets refelected all round the refelctor including in the areas where there shouldn't be any light.
Most MoT testers tend to turn a blind eye to LED headlamp bulbs as long as the beam pattern is correct knowing full well that if they insist on filament bulbs being present for a pass, i'll simply swap them back after the pass certificate is given, as would most other people.
I would guess their mindset is they'd rather test it as being safe with the bulbs they know i'll be using than force me to fit filament bulbs knowing i'll change them immediately after getting a new test and potentially alter the alignment while fitting them. Shouldn't happen but it does, especially with minor varaiations in bulbs, hence the need for a beam alignment check after renewing headlamp bulbs even with incandescent filament bulbs.
