18 plate F-type R. I have intermittant multiple warning lights appearing, inc E-diff, stability control, two wheel drive only, and more. I'm pretty sure these many warings are as a result of a glitch in the electronics, but I'm loath to take it to my local dealership, who will happily impoverish me running through multiple ultimately futile checks. Does anyone have any idea of common faults that could cause these warning lights?
Thank you
Chris
First and foremost, charge the battery and then see what happens. You should also consider investing in a code reader, when you think how much they charge, having your own will pay for itself after the first use.
Thanks Jim, I'll get the battery checked out, I do have a small local garage who looks after our company cars, he plugged in and found a number of intermittant codes, which he wiped.
