When the car is opened just from the passenger door (keyless) the mirrors remain folded is this correct?
they fold to the driving position as they should using the drivers side
Hi Alfie - I personally do not know the answer to this ??? but I just wonder why you would want to use the mirror if
you opened the passenger door ???
I may be wrong but I think the car was set up that when the passenger door was opened the mirrors unfolded ,
I understand where you are coming from but after 10 years ownership this has only recently been brought to my attention after a battery disconnect and me thinking I might have an incoming gremlin
On the flip side if what I think was happening isn't within the normal format of the in car software it may have highlighted  a gremlin that i wasn't aware of
Definitely something wrong Alfie, the mirrors should unfold and fold with operation of both doors individually.
You could try going into the vehicles settings and also using a code reader, if you haven’t already.
The mirror movement is controlled by the passenger door module which in turn is fed by fuse F1 25A mini in the aux fuse box.
  • Sad 1
Cheers for that Jim
Will  look at pulling the passenger door module for the part number for a replacement,
I can't find a how to but hopefully I won't have to remove the door panel as the information I have found suggests that it is positioned behind the door speaker
This will help you Alfie, as you will see the module sits above the speaker so the card will need to be removed. You may also need to programme the new module.
Normal service has resumed however I can't be sure what the problem was as apart from taking the door panel off and think that one of the plugs into the module wasn't fully inserted,
put it on the scanner and scrubbed a couple of fault codes
thanks again to all members for their input on this thread
