So I fitted a new EGR ( LHS which I believe is B ) and for a couple of hours all worked fine.
Yesterday car gave restricted performance with DSC so I plugged the lady in and the fault code is P045D, control circuit high.
If you leave the car the fault disapears and works fine for around 60 seconds then reverts to restricted etc....
I've cleaned the connector.
Where can I locate what and where the five wires are connected and what are the voltages?
I assume there is a sequence depending on ignition on only and then with engine on?
Any assistance would be greatly appreciated.
Cheers.
