I have replaced my ECU, BCM, ignition and key.  Also the SCM and imoboliser control module. This was done in an attempt to solve an impbilised issue but has still not been resolved. I noticed the park gate light is not light up, not sure if this is the issue why it will not start. Any advice would great.... So frustrating.
  • iain B changed the title to Imoboliser issue XK8 150
This will definitely stop the car from starting as the ecu does not see the gearbox in Park or Neutral. Have a look at the cables on the side of the gearbox, they may need adjusting.
