Has anyone removed a passenger door panel? I have removed the two 30 Tork screws in the arm rest and the 20 Tork screw secreted behind the triangular plastic cover. You are now allegedly able to remove the panel. I have gingerly tried but seems pretty tight, don't want to force in case I cause any damage. Comments and tips extremely welcome. I need to get access to the door mirror plug to check number of pins to ensure I get the correct replacement.
