Hello everyone
I've recently brought myself a 2008 2.2 X-Type Jag estate and fell in love with it on the test drive, have just had the turbo replaced and she drives like a dream the only thing I need to sort is the driver's side indicator have replaced the Bulb but it's not working, hopefully when it stops raining I'll be able to sort it out, would be interested in any Jag car meets in Sussex or Surrey areas
Welcome aboasrd Derek! With your side repeater, remove the lamp as you did to replace the Bulb, disconnect the plug and spray some switch/contact cleaner into the end of the plug and on the contacts in the lamp holder. Refit, test.
You may have to repeat this several times before the combination of dis/re-connect and the switch cleaner cleans the oxidisation off the contacts.
If several attempts don't fix it, do similar with the Bulb and holder but also worth checking the Bulb actually works.
  • Thanks 1
