Problem occurred when battery went flat and an attempt was made close the  roof and it would not complete the locking cycle
after the battery was recharged the roof and closing the rear windows will not work
Hi David
No experience of the XK but not dissimilar problem to one I encountered in my XF following a flat battery. Problem is probably the relevant module had it's software corrupted by the low voltage. One place that has been mentioned on the forums before who deal with this sort of issue by sorting the software is MDM in Coalville Leicestershire. Might be worth giving them a call: Phone: 01530 838666
Unit 4, Wylam Court, Telford Way, Stephenson Industrial Estate, Coalville LE67 3HP
John
Hi David,
You May have to manually close the roof fully in order to reset the system.
