Here I present my conversion removing the parkbrake from it's location above the differential to the spare wheel tub. The diff has to be dropped a few inches with a special tool T10179 needed for the rear bolts. Given space the parkbrake eases out. The actuator was quite rusted and I had to grind every bolt down. However internally it was all ok with new Allens fitted for reassembly. I chose to extend the loom from the parkbrake and feed it to the original plug under the car, the wires to the parkbrake module are very thin. Making a loom rather than intercepting those wires was the easiest option. The parkbrake bolted to the side of the tub with the cable running out to the original route and being reconnected to the cables as normal. The way the cable actuator operates means that for it to be fitted internally there is about one place for it to go. I wanted to do this for a while and although it did not cost a great amount it was a hard days work I don't mind saying.
The place it is situated couldn't be worse for maintenance, if it faults it's a towaway followed by considerable cost. Not to mention the garage has to gather all parts before taking the job on so you lose your car for a month. It really is the elephant in the room for the S Type. Doing this means the actuator is protected from spray, freezing temperature, dust etc. Everything is within reach for servicing. Don't get me wrong this method of EPB is very good since the brake is cable actuated and that lowers unsprung mass but my EPB has not been moved since new and it showed. I had difficulty pulling the EPB cable and all the bolts were a rusted lump. All told this cost about £40 and the original actuator has gone back in yet some clown on eBay wants £1250 for a new S Type parkbrake. Need I say more?
