My electric seat not working with exception of the back support, no forward or back action. Can any one help. 2007 XJ diesel
thanks Simon
Hi Simon, as part of the seat mechanism is operational, there is obviously power to the module and therefore the fault would seem to lie within the circuit of the non functioning parts. So check the switch and the motor mechanisms. You can do this with a multi meter and a 12 volt supply. Before checking the circuitry though, see if you can locate the multi plug that connects the seat's wiring loom to the module and disconnect and reconnect it a few times to "wipe" the contact surfaces.
