Air Con blowing hot and cold !!!
I know that's what it is supposed to do , but this one is doing it at the same time.? I can get the air con on the passengers side to blow hot or cold but on the drivers side only hot all the time and it is very hot.  You can set the controls for low but only the passengers side will go Low. drivers side will always be hot. It blows through the various vents all of them . When you ask for it to blow up top or down at feet and everything in between it will do that, you can hear the motor turning and things moving , so that side of it seems to be working . even without the aircon on there still seems to be a lot of heat on  the drivers side.
Any help would be much appreciated. please don't tell me I have to remove the whole dashboard. I just couldn't face that .
