Hi all, I need to change my Headlights for driving in Europe, I have moved here permanently and my headlights dip the wrong way...struggling to find a source, anyone know a solution or where to get said parts..been looking for a while now,
cheers,Kevin
I don't know where you are in Europe but a local breaker would be able to fix you up probably off the shelf these days. Make sure it is the same type and that hopefully the adjustment system is OK. Repair kits for this are readily available for about 60 quid. By the way the way you need to remove the front to do the job.
M
Thankyou my friend,
I've just come across a set of zenon headlights..any idea if it's possible to replace Halogen with Zenon?
I would not change to Zenon because It requires the self levelling setup/relative sensors/wiring and software changes to your system.
M
There a lever inside the heandlight that you can flick and its alters the headlight pattern, no need to swap them
but this is only possible on the HID headlights
if you have halogen ones, then I think you would have to use the stick on bean benders or swap the lights, halogen ones are not interchangeable with HID ones as the wiring is different.
  • 2 months later...
Sorry about the late reply..been busy with the house in The Czech Republic...still struggling to find some LHD headlights though!
thank you for the input everyone..
