Hello all..
I'm after some advice please.
Recently,  I had the O/S rear flexi changed..before this there was a bad brake fuild leak which emptied the system.. so new flexi fitted , brakes bled and a stiff pedal. However, upon firing her up LIMP MODE and every light on the dash..engine management, traction control,  air bags, brake warning lights, air bags the lot..
So disconnected battery left for a time..my mechanic friend tried to knock lights off dash..all to no result s..prior to this brake leak it was fine...anyone with any input/info or a similar issue in the past would be greatly appreciated
I had the same problem with my X350 after changing the rear brake pads. It turned out to be the battery, which was about 5 years old and showed no signs of failing up till then.
Good luck
