My 3L "S" Type has done only 55000 miles over last 10 years - all of this trouble free until recently when I became conscious of increased road noise/drumming when travelling over rough/uneven road surfaces. My local trusty garage diagnosed the problem immediately as worn shock absorber bushes and said that this was a common problem for "S" Types of this age irrespective of mileage. On his advice and at a cost of nearly £800 he fitted new bushes all round but this has not resolved the problem. Does anyone out there have any suggestions as to likely cause.
I wonder if this is just wheel patter, you don't say if you had your front wheels checked for balancing or any damage. I had a bulge on one of my front tyres which gave the symptoms of wheel patter. I think that might have been a much cheaper way than £800 :-)
When did you check your tyre pressures last, that's even cheaper :-)
Thanks Alistair - Had new tyres all round and wheels balanced just a couple of days before the shock absorber bushes were replaced. Have always had slight drumming from the low profile tyres on 18"wheels but sadly this is much more than this.
Thanks Alistair - had new tyres fitted and wheels balanced just a few days before I had the shock absorber bushes replaced. Have always had slight drumming from my low profile tyres and 18"wheels but sadly this is more serious.
  • 3 months later...
Sounds like anti roll bar bushes and drop links need changing. I had a problem with noise on bumpy roads and changed the bushes and links..... now nice and quiet!
Many thanks - your suggestion is spot on - Had the anti-roll bar bushes changed back in November and this cured the problem immediately. Wish now I had not spent £800 on the shock absorbers !!!
I would have had a chat with the garage, as their diagnosis was wrong, I gather it was not a Jag main dealer
Glad you got it sorted. If you haven't already, I would also check the anti roll bar drop links. Once the main problem has been solved (the "D" bushes) It tends to have a knock on effect to the next weakest point (the anti roll bar drop links) This is a simple fix and very cheap too! (£28 a pair from Jaguar Spares North East 0191 586 7770) Happy motoring.
(oh, and I have no association with JSNE, it's just the cheapest place i found!)
Roy
Thanks Roy - I appreciate your advice and will discuss tthe drop links issue with my garage when I get back to the UK - We are currently over in Perth WA until 15/2. I will also mention Big Al's comment although I don't intend to make a big issue about the wrong diagnosis as our "man" has been looking after us really well for nearly twenty years and I don't want him to be out of pocket.
