I have a 2001 x type that is making a roaring noise and vibration from underneath the car when you drive above 50 mph. thought is it might be the prop has anyone got any thoughts or expierence of similar circumstances.
Hi Chas, If you can see no obvious signs of something wrong under the car or in the engine bay, then I would suggest that you get the car on a rolling road, unless someone else can help you, good luck.
