Does anyone know how easy it is to replace the XKR Emblem on the right hand side of the rear of the car (containing boot lock) as mine is a tad worn??
I have a '96 XK8 and its held on with automotive tape, presume the XKR is not that much faster to stop it flying off and needing nuts and bolts :-)) . Tape should be on the new badge, if not any body shop should help you out.
Hi Dave,
You may need to heat the tape up to get it all off.  Make sure it is thoroughly clean before fixing the new badge.
Dave
