Hi Guys, I have an S-Type Jag, 2004 Diesel 2.7 manual. I'm a decent mechanic and like to do my own jobs. Do any of you know of a scanner in the cheap ranges that will actually turn off warning lights, such as ABS, etc? I've heard they make some in China that will do the job and they are very reasonable. Please don't recommend that I take it to the dealer, I'm not in the business of handing over large amounts of money for simple jobs and being ripped off! Alternatively, do you know anyone in West Midlands, UK, close to Wolverhampton, who has the gear to switch this off for me for a cheap price? Thanks very much, Phil
This posting should help from the lounge
  • UK/Ireland LocationOther/NonUK
Posted Today, 10:42 AM
I faund a site where you cand see how to reset service light for your Jaguar.
Full procedure how to reset service light Jaguar. If you like to reset any maintenance Oil light after an Oil change. Or reset check engine light, airbag light, inspection key or insp errors when maint reqd, for Jags cars. Or any warning light for service reminder which appears on the display.
If you whant to reset any warning light for your Haguar S-Type or reset service light for Jaguar XF or reset maintenance light for Jaguar XJ, you cand find this information hear.
http://resetservicel...e-light-jaguar
  • 2 years later...
every one is looking for the solution for the abs lights on the dash board , if you realise this problem only occur after you change brake pads or done service on the brakes, solution for this problem , its not money , just need the to bleed the brake fluid 100% do not leave any air  you never thought about this one did  you I fix my problem ,after I got the mechanic to  reset  the computer ,not bad ? jaguar and they thousands off dollars to fix errors some times caused by them suckers happy dring every one
Phil,
You can reset the service light on the S type by doing this:
  1. NOTE: Steps 2 to 5 must be completed within 3 seconds for successful service mode resetting.
    • NOTE: Ignition key in the OFF position. Press and hold down the trip computer CLEAR/RESET button.
    2. Continue to hold down the trip computer CLEAR/RESET button and turn the ignition switch to the ON position.
    3. Release the trip computer CLEAR/RESET button.
    4. Press and hold down the trip computer TRIP button located on the left-hand steering column multifunction switch.
    5. Continue to hold down the trip computer TRIP button and press and hold down the trip computer CLEAR/RESET button.
    6. Continue to hold down the trip computer TRIP and CLEAR/RESET buttons, RESETTING SERVICE MODE will display in the information and message center if steps 2 to 5 are completed successfully.
    7. After 10 seconds the information and message centre will then display SERVICE MODE RESET once the process is complete.
    8. NOTE: If the information and message centre does NOT display SERVICE MODE RESET, steps 1 to 8 must be repeated.
    Release the trip computer TRIP and CLEAR/RESET buttons and turn the ignition switch to the OFF position.
ATB
Trevor
  • 5 months later...
  On 9/11/2012 at 11:33 AM, Jagmansol said:
Hi Guys, I have an S-Type Jag, 2004 Diesel 2.7 Manual. I'm a decent mechanic and like to do my own jobs. Do any of you know of a scanner in the cheap ranges that will actually turn off warning lights, such as ABS, etc? I've heard they make some in China that will do the job and they are very reasonable. Please don't recommend that I take it to the dealer, I'm not in the business of handing over large amounts of money for simple jobs and being ripped off! Alternatively, do you know anyone in West Midlands, UK, close to Wolverhampton, who has the gear to switch this off for me for a cheap price? Thanks very much, Phil
Hi phil
Look on eBay item no 321730813884 perfect reader and cheap too i bought one gets into everything its actually better than the vixen i had when i was a AA Patrolman. And at £40 and free next day delivery you cant beat it.
Absolutely brilliant
Dave
Welcome to the Club, David.
I have a £20 one from eBay, and it does not do too badly.
One thing that mine won't do is getting rid of the warning light and service required that appears for a few seconds when I switch on.
Keep sharing experiences,
Hi peter
That one i gave you the item no for does it all.
As it is a can bus reader and you can get live data on all systems.
Cheers Dave
