Hi all. I have a 1999 XJ8 with 110,000 miles on the clock. I have two warning lights on the dashboard. One is sayng that my Stabalisation system has failed and the other is my ABS warning light. Is this a common fault? I have checked the appropriate fuses and they are all intact. Could it be my ABS and stabalisation control module? and if so is that an expensive job to do? I would welcome any advice from other members. Thanks
Greg
Could be an ABS sensor fault or the link leads to the sensors at the front.
Could also be a throttle body fault but quite rare.
Or it could be the ABS module that has failed.
Ideally you need the fault codes reading. Then I can advise further.
