Hi guys, just bought my first jaguar, x type. And I just luv it to bits. Couple of things I need help on, it's fitted with 18 inch rims with low profiles, can anyone advise the correct pressure. Also does one need a code for the radio, as I can not find one in the handbook or service history. Thanks in advance if you take the time to reply.
Hi Derek
Welcome to the club !
As for the tyre pressures...If they are standard rims and tyres then the owners handbook should have the pressures. If not fitted as standard, I'm sure I have come across a calculation somewhere but in general, 30 psi all round should do it as a starting point. Anyone have similar tyres (profile, width, etc) that can advise?
As for the radio code, if the memory is not erased then usually a code is not required.
Enjoy your Jag !
Regards     Trevor
