xtypev6sport estate.
parked car up locked it as usual.came out following morning unlocked car key in ignition would not start.
battery o.k dash fully lit.towed to garage by AA.car has been there three days and nobody has yet found the fault.
HELP any ideas.
Sounds a bit mystifying, Pete.
I had something like that on a Ford Escort years ago and after kicking it a few times found out that it was a fuse.  A garage should have found out if it was a fuse, unless they have not been bothered even kicking it!
Not only that, the AA usually try to diagnose the problem.
Good Luck & keep ringing the garage.
