I want to renew rear discs and pads on my 2009 xj6 any advice would be very welcome about the E P B
Sam
Welcome to the Club, Sam.
I don't get my hands oily any more, but there are quite a few very knowledgeable and helpful people around here who can help.
Peter,
found this any help??
For those who want to change the rear pads Jaguar recommend that the EPB (hand brake) is calibrated as detailed below.
This is taken from Topix and is an update that applies to ALL XF's and supersedes TSB JTB00208/2010 dated 31 August 2010
Cars Covered
S-TYPE VIN Range: M45255-N91220
XF VIN Range: R00001 Onwards
XK Range VIN Range: B00001 Onwards
XJ Range VIN Range: G00001-H30057
XJ Range VIN Range: V00001 Onwards
After completing any mechanical service work on the Park brake actuator, Park brake cables or rear brake calipers
through which the Park brake operates (including brake pad replacement), the Park brake must be re-calibrated to the
procedure in this bulletin. Failure to do this may result in incorrect operation of the Park brake, with warning lamps
illuminating and Diagnostic Trouble Codes (DTCs) C1801-00 or C1802-00 being stored.
1. Reset the EPB module as detailed below
a. Switch off the ignition.
b. Disconnect the battery for 30 seconds (see TOPIx
Workshop manual, section 414-01).
c. Re-connect the battery.
2. Start the engine.
3. Firmly apply and release the footbrake five times.
4. Confirm that the message 'NOT CALIBRATED' or 'APPLY FOOT
AND PARK BRAKE' is displayed on the instrument cluster
message center. This indicates that the parking brake is in
calibration mode.
5. Lightly press the footbrake pedal.
6. Apply the parking brake by using the EPB switch.
7. Release the parking brake.
8. Release the footbrake.
9. Confirm that the brake warning lamp is no longer illuminated on the
instrument pack and that the 'NOT CALIBRATED' message is no
longer displayed in the message center.
10. Apply and release the EPB five times to ensure no error is present
