Very strange goings on with The Princess today.
Parked, switched off and then a few seconds later re-started to move her slightly. Had all the fails, transmission, park brake cruise, traction, you name it.
Switched off and on again, powerfolds retracted but other than that all ok.
Switched off, went in the house for a minute and came back to find doors all locked with the keys still in the ignition.
Other than that, sweet as a nut :)
Not a battery problem as I put her on trickle charge regularly and a quick battery voltage test produced 12.4 volts off load.
Spooky.
Further to this spooky behaviour, apparently, if you try to start the car too soon (a couple of seconds) after switching off, the car's systems are in a sort of electronic limbo and become confused.
I'll certainly remember that in future.
